查看: 1104|回复: 1
AS3990 AS3991 AS3992芯片技术参数对比表
高级会员
Rank: 4
发表于 2015-2-26 17:55:36 | 显示全部楼层 |阅读模式
The AS3992 UHF Gen 2 Reader chip
The AS3992 UHF Gen 2 Reader chip is an integrated analog front-end and provides protocol handling for ISO18000-6b/c 900MHz RFID reader systems. Equipped with multiple built-in programming options, the device is suitable for a wide range of UHF RFID applications.
The AS3992 is pin to pin compatible with the previous AS3990/91 IC’s. It offers improved receive sensitivity to -86dB, fully programmable Rx DRM filters on chip and pre-distortion. Fully scalable, the AS3992 is ideal for longer range and higher power applications.
Offering DRM compliance on chip, combined with improved sensitivity and pre-distortion allows the AS3992 to be the only true world wide shippable IC. The reader configuration is achieved through setting control registers allowing fine tuning of different reader parameters.
The AS3990/91 UHF reader chip
The AS3990/91 UHF reader chip is an integrated analog front-end and data framing system for a 900MHz RFIDreader system. Built-in programming options make it suitable for a wide range of applications in UHF RFID systems. Designed to simplify the design and implementation of an EPC Class1 Gen2 reader, this IC requires only a standard 8-Bit microcontroller with minimal other components.
The AS3990/91 comprises the EPC Class1 Gen 2 protocol (ISO 18000-6c) with digital high speed logic up to the framing level and supports the ISO 18000-6a and ISO 18000-6b Protocol with direct data mode. The Interface to the microcontroller can be either a 4-pin serial data Interface (SDI) or alternatively in case of high data rates are necessary an 8-Bit parallel. The frame management will be done using a 12 Byte FIFO in order to decrease processor workload and ensure a smooth data stream and correct protocol handling. All low level transmission codecs and CRC generation is done internally.
Comparison of austriamicrosystems RFID Reader IC Family
AMS AS3992
AMS AS3990/1
Rx Sensitivity
-86dBm
-66 dBm
Rx sensitivity with +5dBm from antenna reflection
-73 dBm
-65 dBm
Current consumption
85 mA
85 mA
Register count @16 Bit
Register count @ 8 Bit
32
32
SPI speed
2 Mbps
2 Mbps
Fully compliant with USB Power Supply
Yes
Yes
Internal LDO for supply noise rejection
YES
YES
Link frequency support
40,80,160,250,320, 640 on chip
Self Jammer measurement and gain optimization
YES
YES
Input linearity high gain/ low gain setting
+11,5/ +18dBm
+11,5/ +18dBm
Filter setup
Internal analog Filter – 50 dBc @ co channel
Internal analog Filter; -6 dBc @ co-channel
Dynamic filtering
Yes
Yes
LBT Rx Sensitivity
-86dBm
-66 dBm
Carrier Cancellation Technology
NO
NO
Tx Phase Noise at 200Khz offset
-122dBc/Hz
-122dBc/Hz
Transmit pre-distortion
Yes
NO
Advanced receiver architecture:
Low power radio architecture
Coherent IQ demodulation
Yes
Yes
Advance DSP
No
No
Software / Firmware
C-code based on 8051
Radio control, Reader configuration and host libraries on Win CE, XP or Linux
Yes – Sample code based on open platform QT for GUI
Price (1K)
$ 41.41
AS3990: $ 33.64
AS3991: $ 36.89
Download the Data SheetAS3992:
AS3990:
AS3991:
新手上路
Rank: 1
发表于 2016-7-17 17:02:11 | 显示全部楼层
很给力,顶一个!
您需要登录后才可以回帖 登录 | 立即注册
小黑屋|手机版|Archiver|EEFOCUS
GMT+8, 2019-7-21 07:23 , Processed in 0.061937 second(s), 12 queries , MemCache On.
© 2001-2013 Comsenz Inc.
